Stock 6.0 truck flexplate, LS2 pilot bearing, and your current clutch will work for the SM465/LSX motor. It worked flawlessly in my truck before I exploded it.
You should do some checking on this before buying into that advance adapters flywheel. Don't know if the 4.8 and 6.0 use the same flywheel (they both came with a standard factory) but I got my 4.8 flywheel from OReillys brand new for $50 and it bolts to the factory sm465 clutch. And the ls pilot bearing was the exact same as the one that came in my clutch kit for an 85 chevy.
