Here's a pic of the grill, I drilled 60-5/8" holes, and jig sawed the headlight holes and mounting holes for the GMC emblem. I mounted Summit offroad lights too. Also, the radiator is mounted, with some more trianglarity, to make the front stronger.
gm500hpwrat said:Looks good. I purchased a customized x-chassis from hendrix and picked up about 2 months ago. My rig will be somewhat similiar to yours. I will be mounting it to my k15 frame thats left. Cutting off 6ft of rear frame because im doing 4 link and the back end is all tubing anyways. Keep up the good work. Art
gm500hpwrat said:DOM chassis. Yeah im sure its going to be a lot of work. Im still in the demo phaze on the existing body and electrical. Im going to do my sheetmetal stuff way different than any of the other x-chassis, its going to look more like a dezert truggy. I got the recessed bracing like everybody else does but im only using that for strength.
jekbrown said:lookin good JK... you are about 6 months ahead of me.
btw, how tall is the cage from the top of the frame to the top of the cage (above the seats)???? Just wondering if my rig is gonna end up freakishly tall based on the design/numbers I have thus far... lol!
j
JK5 said:Sweet!!! DOM is the way to go...![]()
Are you gutting the factory wiring like I am?
Any new progress??? It sure is tough, getting the motivation to stay on these BIG projects...and I thought I'd be done by now.![]()
jekbrown said:damn... I think 38" from seat bottom to cage top is exactly what I have modeled in autocad right now. lol! I'll have to check the frame-to-top height...
good to know I'm in a similar ball park anyway. Thanks for the measurements. My rig is going to be a trail rig, not a comp rig... so if it is a little on the tall side, its all good.Is that 67" wide measurement at the rockers or the "arm rest tube" thingies higher up? Right now my rockers are about 58" wide...
j
gm500hpwrat said:Yeah Im gutting it and if it ends up a scrap pile in the end, I'll just by a hotrod kid from painless. Yeah its hard just finding the time between work and playing with the rugrats and mowing the lawn.
nvrenuf said:I wish someone would make a kit.![]()
madmike said:Bluggy's lookin' good, Jerry! I'm almost done down here in Masontown, Pa, be home next Tuesday for awhile anyway. Keep up the good work!
I'm hoping I can install my new doubler set-up over the holidays, and try to be ready when you are!
Mike
gm500hpwrat said:Are you talking about Stephen at ORD? Because his kit costs way the hell more than that. Try in the 3k's somewhere, and I believe its weld-on. Hendrix makes one for the toyotas that will fit full size trucks. Im doing one right now.
JK5 said:After purchasing DOM steel, cutting disks, 30 lbs of MIG wire, 3 tanks of argon mix, 3 saw blades, grinding disks and etc..roughly $1000 for material.
there is no possible way someone could build a solid tube chassis for $1600
without losing their a$$!!!
