What you can't see yet:
new 14-42-17 IROKS
505 Performance 503 cid big block with edelbrock alum heads, alum water pump, old multipoint efi and valvetrain, etc.
Dynatrac ProRock 60 Front (with same guts as before but with Superior shafts and CTM joints)
New Warn 9.5ti
Premier Power Welder (hate to bite the bullet on this one but it's a handy tool to have)
Mini pretty much summed it up about the frame rails. I really wanted to start with a pile of tubing but there are too many things that are already done to this chassis to abandon when we're short on time. The list of projects really is pretty big but nowhere near completely fabricating from scratch. LOTS of stuff will bolt back in, like seats, harness, shifters, glovebox, all the wiring, the brake system, etc. And it's going to work out nicely, the motor is a little higher than I would like but way better than before, the framerails are quite a bit wider than I would like but are firmly attached and very functional, the cage is a little heavier than I would like but is good enough and on and on and on.... It's going to work better than it did and it worked pretty darn good before.
When i look at the existing framerails and the one factory crossmember that's left, I kind of wonder why myself.
Factory K5 skins go back on it, I'll probably use the stock hood skin again, it's relatively straight (enough). I'm looking at mounting factory mirrors, just to solidify the look a little. It's starting to get a little sketchy calling it a K5 but I'll keep doing it just out of habit.
I'm a little nervous about the highway miles, mostly from a law enforcement standpoint. We are paying particular attention to as many details as we can, like lights, mirrors, mini fenders, windshield, etc. After that it comes down to the big stuff that we just can't get away from and really shouldn't have to since we're going to be mostly legal in this state. Hopefully we blend in with the rest of the caravan and stay out of trouble by driving like I have a brain.
Fox's chassis will be nicer than mine, I'm really wishing I has his windshield area design since his will be really easy to put a 'shield in and mine's a major pain in the butt. ps, it's not much right now but the pile of tubes on the K5 chassis behind wally is the new uav chassis....
new 14-42-17 IROKS
New Warn 9.5ti
