It does and I didn't even notice it until after I paid and started loading it on the trailer.The ‘79 K-20 ( ? ) has gotta tach - extra points !
I can look at them tomorrow, but it will take time to start pulling parts from these.If either one of these have the crossmembers with the riser brackets please put me in line if they aren’t spoken for ?
Thanks, Tom
It’s all good !I can look at them tomorrow, but it will take time to start pulling parts from these.
Thanks, Tom
Nope - not those small 90* “L” brackets that position the secondary crossmember on the ‘73~’79’s after the frame upward bend on the K-10 & K-20 skid-plate option ( from what I can tell the narrower ‘77 and earlier K-5’s and all Burbn’s straighter lower-longer frame rails don’t require these ).Riser brackets?
Are you talking about the ones for the secondary crossmember that was used with the skid plate?
The ones I’ve been talk’n with KENNYW about are the older style setup from the ‘67~’75-ish brackets ( see pics ) that tie in the upper frame rails to the lower mounted crossmember - also, the mid-seventies version that wraps around the frame rail on the driver side but still uses the riser brackets on the passenger side ( added a pic of that one too ).
NOTE: pics are having trouble loading - I’ll try again in a little while. It’s fixed now.
Sounds good !Well that was way easier than I thought... unlike normal, something was right where I thought it was, lol.
There's a good chance I'll wind up using the crossmember, but doubt I'd ever use those brackets.
Sounds good !
If ya’ decide you won’t use/need the brackets just let me know and I’ll fire up the ole Pay Pal machine.
I’m with ya’ on things not usually being where you thought they were…
Will do !Just PM me your address and I'll figure out how much it will be to ship those brackets.
And for info's sake, I'm nearly positive that crossmember and brackets came from a '78 K20. The crazy SOB was converting the truck to a 2wd, after stripping and painting the rolling K20 chassis.
