Squeeling like a Pig
JW86
Bolivar, Texas
looks like my A.I.R. injection pump is toast! any tips or advice for the change out? have ordered a reman from LMC which should be here for the weekend. Is there any way to check the diverter valve operation? /forums/images/graemlins/confused.gif
Mine locked up when I put the belt back on after I had unhooked for a while. I just took it all apart and greased the hell out of it and it works fine. Probably took about 15 mins total. You should have went to a junkyard for the pump instead of LMC...much cheaper
