srw hubs on cab and chassis 14b = srw 14b?
muddybuddy
1 ton status
Northern, VA
is the only difference between a 14b srw and a 14b from a cab and chassis the hubs? i know the wms on the cab and chassis is 63" and a srw 14b is 67". so swapping hubs would make it the same wms right?
the only input I have is that the casting on the 14 bolt srw hubs made my dually 70 alot wider.
so no real input~!
brake backing plates flange set farther inward than SRW. Could prob use it with weld on brackets for disc brakes if you used the SRW hubs.
thats what im doing
