pseudomike
I got a set of stainless brake lines for a 73-87 that run from the Master cylinder to the proportioning valve. They are pre-bent including the coils. I bought a whole set and did not use these cause my proportioning valve is on the master cylinder and not the crossmember in front of the engine. They are a fairly common rust or wear out item.
$25 shipped takes them away.
