Stalling out when hot
cabledawg
Secret Squirrel
Highway to Hell
88 4x4 Burb 1/2 ton. 350/700/208. Runs fine when cold, but keeps stalling out when the engine is hot. Idles ok but the second I touch the go pedal it stalls. Dumping too much gas into the TBI. I can sit and watch it pool up when the engine quits. When I start it back up, lots of black smoke and reeks of gas. I've already checked the EGR, PCV and the entire TBI unit. I took the belt off the smog pump (AIR system) and at least now it will start when flooded. Any help will be much appreciated.
Not sure what that is but the girl who owns this asked around and found out it might be the temp sensor on the intake manifold. Same thing? None the less, I'll try swapping that out and see if it works.
If you can watch the gas pool up on the throttle plates when the engine if off you probabally have a leaking injector. They should not drip at all when the engine is not running. Have you checked for trouble codes? That should be the first thing you do before randomly replacing parts.
No it was pooling up right before the engine quick, but it was the temp sensor so it is fixed and runnin like a champ.
