If you go 6" wheel beware of the "donut" look if you get too wide of a tire. Narrow rims / narrow tires for correct stock look.
Equivalency table
Rim width Minimum tire width Ideal tire width
6,0 Inches 175 mm 185 or 195 mm
6,5 Inches 185 mm 195 or 205 mm
7,0 Inches 195 mm 205 or 215 mm
5 on 5"I’m just going to go 15x8 all around with different tire size front and back. It appears you can go from a skinny tire to fat tire fairly easily on that wheel size.
15x8 and the bolt pattern or is what? 5x4.75 or?
@Chief Brody
I vote for the first pictureThis “racing” look is sweeeet. But I think I’d like to deviate a bit and go more stock.
Previous owner told me they lowered the front. So I’m pretty sure they just cut a coil on the front springs and left the rear.
Still 15x6 should work with the wheels sizes of 225/75/15 or a 235/75/15. A guy I know has 15x6 just need repaint. That will save me $$$ going that route.
Yeah I’m really on the fence with that thin white wall.I am a blackwall out guy, but to each his own
