Went to fire up the Jimmy and noticed the starter was running on and the key would not turn it off. I had to stop it by the battery disconnect. Once the motor was running I had to shut off the disconnect and the motor would stay running but without any charge going back to the battery, and the key would shut the motor off as normal. I'm thinking the problem is the starter? Ant thoughts on this?
