I would pull the starter,,check the flywheel teeth,,rotate the flywheel if needed,,,check the starter on the ground make sure the bendix works...Install the starter with the one bolt,,,install the brace,,,stick another bolt in the other hole,,,take a ratchet strap or block of wood and brace the starter..and give it a shot.
get it cranked and get it home....
hell.. I got a slant six dodge started one night after it threw a rod and knocked the starter loose..
