pismorat
On Friday I'm taking my truck up to the local mountains to leave it and offroad it for the rest of the year. The old starter had been clicking and not cranking over from time to time, so I decided to replace it with a brand new high torque one. I installed it today with a new "hot" wire from the main battery and cleaned all the terminals. It started so fast and perfect the first time, but then right after shutting it off (cold or not), the thing just clicks and clicks (like the old one would) when you turn the key. After you let it sit for 5 or so minutes it'll start right up again. What could be causing this? I have dual Optima dry cells that seem to hold a charge and a 120 amp alternator that is charging them when running. I have checked all grounds and they all seem good...please help!!!!
plenty of other apps that ran it way before it was found in Furds..
