the intake side of plug will have more color than the exhaust side. Plus each cylinder has different air flow. black sooty plugs or bright white are colors you need to worry about. the plug in bottom picture right looks like oil, if cyl 8 could be trans modulator TH350 leaking, or rarely brake fluid from master leaking into booster then scavenged by intake vacuum. the other plugs color are acceptable
