Stormin
Registered Member
I am helping my friend build his 79 stepside. The ultimate goal is 42" tires with little or no suspension lift and obviously a lot of sawzall work. We are still trying to decide on spring choice and location and I had a few questions.
the front:
We are considering swapping the rear 52" springs to the front. I have read the tech article but I had some questions. I understand that putting in a longer spring requires moving the spring hangers but I don't understand why in the tech article both of the hangers were moved forward and the longer swing shackle was used. Looking at the final picture it seems to me that moving just the front mount and using the stock length shackle would result in the spring being in the same location with the swing shackle in a vertical orientation. Is there a reason why the shackle should slant toward the spring?
Also there will be a bit less weight in the front as we are moving the battery and radiator to the back and losing all the creature comfort type stuff (ac, heater, etc). Should we remove some of the springs from the pack to gain more flex?
the rear:
In the rear we will be losing the outer fenders on the stepside bed, cutting two feet out of the length, and shortening the width so the bed sits inside the frame. We are considering moving the axle forward a foot to a foot and half. This will provide a wheelbase the same as a stock blazer or a couple inches shorter. We haven't yet decided what springs to use in the rear. We are considering buying a set of fiberglass springs. Has anybody had any experience with them?
My last question has to do with locating the axle after you move it. If we move the axle forward does the pinion angle need to remain the same as stock or must it be adjusted? Also, when we move the rear springs are there any geometry rules we need to consider with spring mounting? For instance does the relationship in height between the front and rear mounts matter, or the orientation of the center pin of the spring to the frame of the truck?
This is my first complete build involving a lot of fabrication, so I'd appreciate any advice anybody has. I'll be sure to get some pictures taken and post em up as we go!
the front:
the rear:
. Here is what I think I understand please try to make sense of this if you dare and correct me if I'm wrong
