Starting after years, any tips?
77ck5
Arizona
I want to try and start the 77 Blazer when I get back to it in a few weeks but it has not been started in years now . Any tips? I plan on pulling plugs and putting some oil in cylinders that someone had mentioned then some new plugs for it. Have new belts to install as well. I thought I should maybe disconnect fuel tank and possibly just fill the bowls ? Should I maybe pull valve covers and put some oil on them prior to turning over as well? Any other tips appreciated. Hoping to get it running enough to get it on a trailer and get it out of the mountains and at least over to Grass Valley, CA for now. I'm no auto mechanic by any means , mostly just 2stroke motos so any help appreciated
You could just spray WD40 or just some atf in the cylinders too. Definitely disconnect the fuel supply. If/when you go to try and use the old gas, I would try to dilute it with new gas and toss in a few additives like Sta-bil and an octane booster.
Other than that I’d check trans fluid to make sure it’s full enough to not burn the pump.
Filling the bowls should get you 30-45 seconds of run time.
I would start with removing the spark plugs and squirting ATF in the hole, let it sit at least an hour, preferably overnight.
Then, before you put the new spark plugs back in,
Like @Fastereddie said rotate it first by hand to make sure nothing is going to bind.
Then hit the starter and let it spin getting the cylinder walls lubricated and possibly a little oil priming.
Then put the spark plugs, and start it.
Now for the fuel if it's low, add fresh fuel it should be fine.
If it was full I would disconnect and run from a can first, then deal with the old gas
I’ll go with the atf then and rotate it a couple days later. Maybe 1/2oz a cylinder or less? No idea how many years old gas is but probably over 10yrs or so. going to fill bowls thru the vents and see what happens there. Just need it to run enough to get it able to drive on to a trailer for now.
If using atf use the type f fluid for older Fords.
Dextron and most others have friction modifiers and are not real good for cylinders.
I stand corrected, apparently I am not the only one who has made that mistake.
AI Overview
  • This logo represents Dextron, a technical specification and trade name for automatic transmission fluids (ATF).
  • It is a trademark created by General Motors, used on lubricants for vehicles.
    • Various brands, such as Chevron and Valvoline, manufacture products that meet these technical specifications.
3 sites
  • Valvoline ATF Dextron Mercron III Transmission Fluid – Bakes ...
    Valvoline ATF Dextron Mercron III Transmission Fluid – Bakes Online. STOCK UP ON WAKE GEAR HERE! Home. Boat. Engine. Wake Gear. Br...
AI Overview
Dexron (often spelled Dextron) is a brand of automatic transmission fluid (ATF) created by General Motors. It lubricates, cools, and cleans parts inside a car's transmission
Either way, kennyw's idea of Marvel Mystery is probably the best way to go.
AI Overview
3 sites
AI Overview
I could be wrong but marvel mystery oil is atf with no friction modifiers.
It dissolves the same things, so use whatever is cheaper.
I use both, usually whatever is within reach
I know there is Marvel at the place and ATF as well. I will try to turn over by hand as soon as i get there in a week or so. It running would sure make it easier to load on a trailer otherwise I can round up a few locals if need be to help
Put the fluid in first before you turn it, if it's stuck it could loosen up for you to turn it.
I am not sure if you meant it in that order, just making sure
