Or, you do it yourself.
Front on jackstands, tires off the ground, take a piece of chalk and make a vertical mark in the front of each tire. Measure distance between the marks. Rotate tires 180° so that the marks are now towards the rear of the vehicle; measure distance between the marks. Rear measurement larger than front measurement = toe-in.
Adjust tierod length for more/less toe-in. Can't remember what the number should be - 1/8 to 1/4" or somesuch. Tighten adjusters, take for test drive, notice position of steering wheel; once toe-in is satisfactory, work on the draglink to center the steering wheel.
