steering arm torque spec needed
hunter
Houston,Texas
I need the torque spec for the 3 fastners on the steering arm please. If anyone has this info please reply.
Anyone?
Im literally doing this outside right now :D
I have the front lift on and steering arm on, just need to install shocks and tighten everything.....need this torque spec bad :crazy:
My Chiltons says 90 ft/lbs and to use new nuts.
not sure of the exact spec but they need to be TIGHT, minimum 100# i think, i didnt ever measure mine, i just cranked on it with a big ratchet and 4 foot pipe till it felt pretty damn tight. never had any problems (which is more than i can say about the rest of the truck)
That's why people have such a hard time taking off the arm. :confused:
Thanks guys, the fronts all done. I will have to do the rear tomorrow...damn rain :frown1:
I appreciate the help ;)
mr_clean said:
Did I miss something? Rear steering arm bolts? :confused: :confused: :confused:
lol....I am installing a lift kit which involved removing and installing a steering arm on the front so I needed the torque spec. I finished the front lift, with help from CK5 of course, and couldnt finish the rear lift because it started raining like hell, therefore I will finish the rear lift tomorrow :D
I've never know anyone who had to remove the lifted arm i put on and tightened.....
the only complaints about arm removal ive ever heard are people removing the STOCK arm, (factory tightened and on the truck for 20+ years...)I never tightened down one of those...... :whistle:
Anytime :thumb:
