TXblueSS
I just bought a 75 GMC Jimmy, and the steering column is having problems. The lower shaft is tight with the steering box, and it seems the movement is inside the tilt mechanism area. I bought a kit off ebay for rebuilding this area, but haven't received it yet. I have already pulled the steering wheel off, and the plastic piece behind with the 6 or 8 wires attached. Then I removed the 3 screws, but now what? do I remove the tilt stalk? and how would I do that? I have pulled out the top bearing, which was toast, but how do I get to the lower one? Pictures would be greatly appreciated.
Thanks,
Tim
Thanks,
Tim
