When I turn the steering wheel all the way to the right, about a half turn from full stop, I can hear a slight scratching/grinding sound. Like a thick piece of wire scraping across a small area as the column turns past that point. It lasts for about a half inch of wheel turn then the noise stops and normal steering continues to full stop. When I turn back to the left, no sounds of grinding at any time.
When I turn the steering wheel back and forth in that one specific area it makes the sound turning right but not left. It only happens on the last rotation of the steering wheel not on earlier rotations. Example: I start turning right, from full left, and the steering wheel rotates one full turn with no grind, another full turn with no grind, and on the last turn when I am at about a half turn from full right, the noise shows up for just that short instance. It sounds like it is coming from the steering box.
I did adjust the sector shaft both up and down from where the book says to adjust it. That didn't make any difference in the sound at all. Same place, same noise level.
Any ideas why and what I can do to fix it?
