blazindorito
I can not drive this truck on the streets it feels very unsafe when I drive it.
I went High Steer. I already had the knuckles drilled and I said what the hell.
I had death wobble before I went high steer and ram assist. I don't have it now but when I hit a bump or something I can feel the left side of the truck want to get the Death Wobble. It doesn't get it but i can barely feel it.
The steering is also really loose. I constantly have to turn the wheel left and right to drive in a straight line.
This weekend I retorqued the bolts to 150lbs on the U BOLTS, Checked all tie rods, and everything under there. The axles were gone thru before I bought them. I am thinking that it might be the gear box that needs to be gone thru.
I am running out of ideas to fix this. It doesn't feel safe to drive on streets.
A lot of WANDERING when I drive it, could it be my castor angle?
What else should I look at? How should the steering feel with a 6"lift all springs, high steer, crossover and all new tie rods. Should it feel sloppy or tight drive straight on a street?
