Ok, I have been trying to fix a steering problem with my 78 blazer. It has what I can only describe as a steering delay. It's not slack. when I turn it, even a little, it will turn the truck, albeit a half second later. I've heard it being cracked springs (found no cracks), cracked frame (found no cracks), rag joint ( got the xj shaft put in), and ball joints (haven't noticed a problem but could still be that). Is this common and what should I be focusing on? I'm even willing to examine all the above again. So starting from a fresh issue, what are the possibilities and the likely order of probable cause(s)?
Thanks,
possum70
Thanks,
possum70
