rowdyrusty
Newbie
i have a 86 jimmy with alot of play in the steering is there a cheap way to fix this
rowdyrusty said:i have a 86 jimmy with alot of play in the steering is there a cheap way to fix this
Tighten the bolts holding the steering box to the frame. If they're tight, look for cracks around the box on the frame. Cracked? Think welding, weld-on brace kit AND bolt-on.rowdyrusty said:i have a 86 jimmy with alot of play in the steering is there a cheap way to fix this
