Steering pump studs
Recon 78
Can you use a 2 mounting stud pump in place of a 1 stud by removing the extra stud and replacing with a bolt?
In a time bind, parts store has a 2 stud but I won't bother if it won't work
TIA
Oops, forgot to give more info
78 K5, 350, this is pump with res.
Yep. The stud/bolt could be 3/8" or 10mm, so watch out for that (yours is probably 3/8").
Thanks for the info
it almost seems like you might be able to leave the extra stud in there's really nothing behind it but nice to know if I can't I can swap a bolt in
