Steering Wheel Revolutions
jimmyjack
Tucson Az
For all you full size steering wheel blazer drivers....... From stop to stop, how many revolutions does your wheel make? Mine goes 3 and 1/4 turns, I can make incredible U turns but I can barely get around a right hand corner. I noticed the rear tie rod for the steering arm is really long and butted up against the other tie rod inside the sleeve so it cant be adjusted. I think the easy solution is to replace the long tie rod with a shorter one but wanted some input from some people first.
creepin' and crawlin'
Jim
My wheel goes 3 1/2 turns lock to lock. 1 3/4 turns each way. It turns very sharp left or right, maybe a little sharper going left. Does that help?
Rene
Yessir it does, I think its just a matter of changing the other tie rod so I can adjust the wheel correctly. Thanks a bunch.
Jim
The long one should be in the front, and the short one towards the back. I just got done changin the ends and I noticed left would hit the mechanical stop at the knuckle, but right wouldn't. I adjusted the length to get lock to lock, then my steering wheel wasn't centered- damnit
. When I use the adjuster sleeve to center the wheel, it doesn't go lock to lock- 2xdamnit
. I wound up "customizing" the steering wheel and turn signal mech to get it straight.
<font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
