odoa3
Ok, I am having a couple issues with my steering. I have a Dana 60 with ORD High Steer and Crossover steering. I put in a new steering box and pump when I put the axle in. This is on a 75 K5 with six inches of suspension lift, and 35 inch Boggers.
First issue is the wheel do not return to center, even when the front end is off the ground. The steering is extremely easy to turn when the front end is off the ground, and not much harder when the tires are on the ground. The alignment seems to be correct. I do not have a stabilizer on, and I don't think I really need it. Any suggestions? I have searched and read the recent thread on this but the information there does not really seem to fit with my issue.
The second issue I have, is that on the trail I really cannot feel where my tires are in their turn radius in rocks. Due to my crappy, broke down seats and the lap belt I can't get out the window enough to see them either. I hope to be able to get some new seats in at some point, but that is not happening anytime soon. You guys have any tricks for feeling where your wheels are? When I am moving forward it is no problem, just when I am trying to inch into position to get up on the rocks.
Thanks for any help you guys can offer. (Yes I am a pretty new wheeler, as you can probably tell.
