Still thinking about H1 Bead locks
Pookster
NYC, NY, USA
Call it a little dream, and not a really good reason to.
I keep envisioning having h1 beadlocks on my tow rig. Yes, I know they are heavy, but the run flats, the never having to go anywhere to get my wheels mounted, so on, so forth...
I want em. Thing is, they are so expensive if you need them "recentered".
is there any cheaper alternatives? I recall tonyp made them, but havent seen/heard from him in a long time.
Dually axle conversion perhaps?
The dually conversion makes the wheels a direct bolt up (that's what I'm doing).
As far as cost, it's probably cheaper to buy recentered wheels than to go for the dually conversion when you consider the cost of axles, gears, lockers, etc..
i assume your talking about swapping in a dually F/R axle.
Mine is the 92 IFS k2500- The beadlocks might acutally clear the front, but the rear would be a little close. (not to mention goofy looking).
I was thinking about the dually conversion kits- the 8 lug to 8 lug conversion, that basically move the wheel mount location out by around 4" (which should fit the h1 wheels perfectly). In terms of extra stress, there is of course extra lug stress but bearing stress should remain the same, since the wheel is in the same relative position as a stock wheel.
These conversion kits arent cheap either- 349 for a pair from JC whitney.
Gotcha, didn't realize it was your ifs truck. I think the 8 lug to 8 lug spacers would be ok on the rear. I would be afraid of them on the front, I doubt the unit bearing thingy's would like them.
I'm swapping in dually hubs for my front but I'll also be using thick spacers for my rear. I got a set of 3.25" steel Arrowcraft spacers originally intended for a dually conversion that I will be using to even out my track width. :thumb:
I know spacers get a lot of flack but I think that stems from problems with the cheapo AutoZone type. I have no fear of the ones I got, they are way over built!
I've heard of people having like the really nice ones and converting to dually with them, breaking when towing a huge load. If you are converting to Dually with them I think its a real mistake. Using spacers for hummer wheels or just for a little more width is a different story. I agree about the IFS front, it could be a problem. Not to mention the stress on the ball joints.
The "Magnum" series adapters are the ones I'm using on my rear D70HD.
[hijack on]why did u decide to go w/ spacers instead of srw hubs? is it cause it makes the rear a little wider than the frt?[hijack off]
When I started my D70 project I intended to run it in SRW fashion so I had the housing narrowed 2.5" per side (just inboard of the spindle seal area) making it the same WMS as my old van style 14 bolt. When I decided to do the dually/Hummer rim thing I had already finished my disc brakes so I didn't want to change back to a full width housing.
The whole deal has a huge :doah: factor about it. :rotfl:
i see, that suxs. i have had similiar miss-haps.
Not much to add to this thread except that the H1 rim weight is WAY overexaggerated. Especially on a tow rig, I would not worry about it.
I've always wondered about this whole wheel weight thing.
I know aluminum is lighter, steel is heavy, but not as heavy as a bead lock, and that the hummer wheels are like 37 lbs with run flats. Granted alcoas would only weigh 20 lbs....
Anyways, Then I looked at the rickson 19.5" tires/wheels. They ALSO weigh 35 lbs for the Forged, 45 for the cast, and a whopping 63 lbs for the steel.
add in the weight of 3/8" steel plate centers and you are looking at a hefty wheel. I also run PVC beadlocks so add another 10lbs to each wheel for those.
