I don't know about your Haynes and this whole 8 o'clock thing, most sb's have it pointing at a cylinder, #1..
That doesn't matter anyway... Like I told you in the first post, if you wanna be fussy, pull it and drop it wherever you want... 1 cyl, 8'clock, the glovebox, it doesn't matter.. It's all in where each plug wire gets fired in relation to the rotor and valvetrain..
If you want to do that, go to TDC, if you didn't know this, you can also find tdc by pulling the ds valve cover.. turn the motor over till the #1 intake valve has opened, come back down, the next time the mark reaches 0, it WILL be at TDC..
drop the dizzy a little before the spot you want to be, if the oil pump shaft doesn't allow it to drop all the way you can either use the bump method to get it to drop, or just repull it, take a long flatblade and turn the pump shaft, thats my prefered method...
I don't know what else to tell you at this point.. BTW, the reason your not at the position it says you should be in, is because your not dropping the dizzy in at tdc, orientating it the way they say, you already have it in.. but again, it should still fire if you've follow what I've told you, ASSuming there is no other issue... But hey, I'm not there..
Is it cranking good? Or is it inconsistent?
