Dont think it works in real life. There is a manifold vacuum formed as the engine wants to suck air- Therefore, the function of ram air is not to boost air speed above atmospheric pressure, but rather to provide as much air that is usable to the engine, Optimally providing 0 negative manifold pressure. That is where ram air helps, by bringing enough air for the engine to burn.
yep,
i wonder why trans ams and other models had factory ram air if it didnt help the engine to get more and colder air, hmm..
:P
the best setup you can have short of turbo or supercharger is a stock type closed air breather assembly with dual snorkel setup with intake venting runnign up to front of truck, just like used on the 82-up L69 HO 305 cars, if you can find one in a junkyard or parts car then snag it and put it in your rig, i have had a few of these cars, its all about getting colder air to the engine, and as much as the engine can take in and if you want i to be able ot take in any more air then get bigger valves and port the intake runnrs of the heads and intake(port match) and polish the exhausts but dont port those
anytihng that you can possibly do to increase air flow into and out of an engine(reduce resistance) then the better it will perform, engines are just big air pumps
and when you are traveling down the road at 40 or 50 or even 70mph there is quite a bit of air restance at those speeds, you can tell that simply by sticking your arm out into the air, that is way plenty enough of a forceful effect to ram air into the intake vent ducts of a duel snorkel vent setup. it can only help to put more air into the throat of an engine, i cannot see how it couldnt, and even nice cool air to boot /forums/images/graemlins/laugh.gif
open element aftermarket air cleaners are a joke, i never run one on any of my vehicles, i find them pointless to even try to have, all they do is make your engine be stuck with having to suck in hot nasty air and why would you want that for your engine if you are wanting a litle bit more performance out of it. i always sell open element pos ones or trade them for tall stock closed element snorkel type cleaners and add another snorkel to them and run my dual setup with flexible ducting up to the grille or rad support, cutting pass through holes in the rad support wherever i can, this does make a good difference in performance, for sure,
those who have doen this conversion woudl agre,e unless they didnt do soemthign right :P
if someone thinks that anything im saying is not true then id have to say that they dont know too much about engines and performance,
each to his own though /forums/images/graemlins/laugh.gif :P
good luck
