Elevator Man
I'm running a stock fan & clutch setup, it cools fine unless i'm in the trail or set and idle for over 5 minutes. I have a 14" pro comp fan (2000 cfm) I am woundering if I could use it as a pusher on the out side of the rad. to help with cooling. Or will it block to much air from the stock fan? Thanks for any advise!!!
