stock fan clutch & electric as pusher?
Elevator Man
Bigelow, Arkansas
I'm running a stock fan & clutch setup, it cools fine unless i'm in the trail or set and idle for over 5 minutes. I have a 14" pro comp fan (2000 cfm) I am woundering if I could use it as a pusher on the out side of the rad. to help with cooling. Or will it block to much air from the stock fan? Thanks for any advise!!!
I have a similar setup: 14" electric fan as auxiliary pusher. Although I haven't had cooling problems lately, the auxiliary fan helps the temperatures a little when it's slow going on the trail, or when I have the AC on in city traffic in Scottsdale.
Thanks for the input, sounds like thats what I will do. I was planning on hooking it up to a switch and relay so I can turn it on when needed. How did you mount your fan? Mine came with a mounting kit but it looks kinnda cheezy. The little pastic rods you stick through the rad.
some channel or angle iron spanning from the side to the center brace... or even some healthy flat stock..
Ditto - metal straps/braces.
