stock pinion angle?
The axle really should be in the vehicle to set the pinion angle. I have no idea what the stock angle would be.
Why can't you slide it under the rig to get the angle right then pull it out and weld it up?
There is no way to tell what angle you need unless it's in the vehicle. Every vehicle will be different depending on vehicle height, transmission, t-case, and wheel base.
