Well, I heard these things are not to strong for a tire. Well I think I can get my hands on one of these pretty Cheap. Would it be strong enought to hold 1 or 2 5 gallon gas cans, with out banging up the body. I figure I have all the holes in the truck allready and it might look pretty cool.
Gas weighs ~8# a gallon, so a 5 gallon jug weighs about 45#. That's more than a 31" on a steel wheel, if I remember right.
What you wanna look for is that the carrier comes with plates (prolly bent) that go INSIDE the fender (you take the taillight out to put them in). If not, if it's just the outside part, run, don't walk. You WILL kill your quarter panel.
Also, on the vertical piece that goes on the tailgate, consider something other than sheet metal screws, as these WILL rip out. Molly bolts or something maybe.
When I took mine off my K5, I put it on the pickup. For the tailgate mount I drilled a hole and stuck a piece of pipe all the way through the tailgate, and welded it on the inside and the out. Two of those, one top and one bottom, and THAT's what the carrier attaches to.
Anyway, for street use and mild froading those carriers aren't bad. It's when you go to 33"s or bigger and start doing crazy stuff that they kill your sheetmetal.
(been there, done that ... can you tell?
-- A
