Np241 I think. Before that the np208
The 1988 was the last year for the 208 in this platform, they strated using the 241 in 1989. Either of these will physically interchange in this vehicle as well as the front driveshaft from any Blazer/Suburban that had the 208/241. Be mindful of the 241 you choose should you locate one, the mechanical speedometer model is rather hard to find and the electronic vss type will leave you without a place to attach your speedo cable.
i see the 4wd "light plug" hanging and the bottom of the 4x4 shifter... should there be another crossmember to support the tcase??
