BlitzK5
Looking to change out my 10 bolt U-joints and I wondering which ones are the strongest to get. CTM? OX? or Spicer?. Also CTM only shows u-joints for Dana 44's. Are Dana 44 U-joints the same as 10 bolts?.
You can machine stock shafts to accept full circle clips (all of the u-joints, even Spicers, can take full circle clips).YZEATER said:isn't it possible to modify the stock shafts for full circle clips. that would be the strongest setup.
YZEATER said:strongest with stock shafts and joints. it would help keep the u-joint caps in place.
