It has been way to long since we have had an update to this thread.
Holy crap Feb? Time fliesIt has been way to long since we have had an update to this thread.
No kidding! Wow, Feb! The sumbish should have been done by now but is snot.Holy crap Feb? Time flies
. That really pissed me off as enough time had gone by there was no way I could exchange it (plus I had painted it). I went back to look at the part number on the invoice and it clearly listed the small block part number but it was a phone in order and not a web order so who knows how this happened. This is now like 3 times in recent history where I’ve phone in an order and got saddled with some unusable BS because too much time had gone passed by the time I could install it. This same exact thing almost happened again yesterday when I called in about a front output for a 30 spline flange on a round pattern 205. I was given the part number of U3002 and was told it was quicker to order via the web than over the phone (even with a credit card on file
. Ooookay then........So when I got online last night and poked in the part number the flange was for a 32 spline. Mine is a 30 spline as I CLEARLY stated on the phone…..crisis averted. No more phone in orders…period! Apparently, 30 spline front output flanges are extinct anyway, so a Speedy Sleeve is in the mail from RockAuto. I sure the hell don't feel like yanking the case out and tearing it down again to change a 30 spline input (that bought from them) only because I have a grooved flange that the front seal won't seal to.
No problem, it shouldn't take long to find a SBC locally.I ended up with the small block version instead of the big block version.
. Many little things that you can't see were done differently in the wiring from lessons learned from rigs before it. This one is probably the tightest and most well routed and secured harness of all previous project rigs. Hopefully, time will prove it once it hits the dusty trails
Definitely looks like one! People on Instagram would believe it too. An HT6AC VL29 Supercharger intake manifoldium 7400 good for 1,000 horse torques
Different engines, different injectors styles and different cause of death. His wasn't a stuck injector, his had a fuel regulator that ruptured allowing fuel to get sucked into the intake by way of intake vacuum until it filled up cylinder #3. He never actually had an injector failure as we originally thought. How he didn't notice the engine acting wonky with that much fuel going into the intake is beyond me but he is tired of me bitch about it so.....didnt robs have a stuck injector that flooded the engine and bent a rod?
I wouldnt trust those injectors!
Are you running factory L29 injectors?Different engines, different injectors styles and different cause of death. His wasn't a stuck injector, his had a fuel regulator that ruptured allowing fuel to get sucked into the intake by way of intake vacuum until it filled up cylinder #3. He never actually had an injector failure as we originally thought. How he didn't notice the engine acting wonky with that much fuel going into the intake is beyond me but he is tired of me bitch about it so.....![]()
When I did my engine swap I was reading up on the L29 on some other forums and lot of people were hating on the factory injector spray tip. There was some Ford application injectors they were swapping to. I ended up with an aftermarket LS1 profile injector and it fit perfectly on the factory fuel rail.Probably the original ones to the engine, but I have a new set of Delphi 17109596 yet to go in it
Interesting. I’ll keep that in mind if these Delphi injectors don’t work out. I’ve never really looked into the performance side of them as I’m not looking to squeak out every pony an engine can deliver but I did see something about these same injectors look like they are interchangeable with some Ford engine or vise versa.When I did my engine swap I was reading up on the L29 on some other forums and lot of people were hating on the factory injector spray tip. There was some Ford application injectors they were swapping to. I ended up with an aftermarket LS1 profile injector and it fit perfectly on the factory fuel rail.
. I swapped this one from a 4.3/5 speed to a 454/auto about 10 years ago. Fun little truck. Its not fast by today's standards, but its fast for 1993 standards.
You'd thinkI ran into an issue with WFO recently where I bought a cross over kit (admittedly about a year ago and didnt open the box), once I opened it there are 2 pitman arms in the box listed as pre 80's ford. I reached out twice telling them about it, and said I would be happy to send them back for the correct one (seems they are out more money with me having extra parts) and no response.
If it is an interchangeable pitman arm ( I dont know if it is), I figured they would want their missing inventory back for the second one.
