No, there looks to be a tiny little shiny spot just above the wear spot on the bearing, on the chamfered edge of the cap. Like what I'd expect if it had been hit with something that had an edge on it.
Thanks for all the replies. This is the only odd bearing. It did, however, spec out just fine with plastigage. As did all the other mains and rod bearings.
Might just button the pig up with some new gaskets and run it....
you should not only use plastigauge, but use a micrometer to measure the main journals in 3 positions left to right, and in each of those positions measure it every 120 degrees. this will tell you if you have taper or out of round journals. plastigauge will not, thats just oil clearance.
Oh dont be a baby. Just un bolt it from the bellhousing.
