...ok I know someone out there has the answer to get a spring bolt out, front spring hanger on the rear passenger side of a K-10 pickup. Siezed so bad I broke my breaker bar(made in taiwan crap) thanks in advance Jesse
well torch is the one thing I don't have, hammering doesn't work since the bolt is hidden on one side, I guess I could buy one of those little propane torches to try and heat it then see if it will break loose.
PB Blaster....seems to penetrate better than WD40. I just did all new ORD bushings up front on mine and pre-soaking did seem to help.
Maybe get a grinding wheel and cut off the bolt head...then use a drift to punch the bolt through with a BIG hammer? Or maybe an even BIGGER breaker bar?
I did this recently...I presoaked with WD40 a couple times a week for 2 weeks, had a BFH, huge breaker bar and an impact gun ready. The bolt was so rusted the bolt head eventually broke off. Trying to drift the remainder out through the bushing was a joke because the bushing absorbs the impact...
My solution was to use a thin cut-off disc on a grinder to cut the other side of the bolt flush. This got the other shackle plate out of the way...then I used a drill with a 1/4" drill bit and drilled through the bushing all around the bolt until it pretty well fell out. Once the bolt and sleeve was out the rest of the bushing came out easily. I used some fine sandpaper to clean the spring eye out and installed new bushings and greasable bolts.
I've heard you can burn em out with even a small torch...but fire and a vehicle make me real nervous!
Rene
<font color=green>Dyslexics of the world...UNTIE!</font color=green>
<a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
just a reminder this bolt is on the rear of the truck, the ones on the front spring hanger, can't grind off the head and drive out cause bolt is to long It will no fit in the pocket the hanger makes. But I will continue to soak it and bang on it till I can get a small torch.
