This weekend I did the front CV shafts and wheel bearings on my 2002 Chevy Tracker (Suzuki Vitara) DD. After battling with a variety of PITA things all weekend I have it done. Mostly.
However...the spacer at the end of the passenger side CV shaft that goes between the unit bearing hub surface and the lock ring groove...I CAN NOT get that thing in there at all. Just not enough room for it between the lock ring groove and the hub surface. If I put it on there the lock ring won't go in at all.
(That's not actually a Tracker CV shaft but the groove illustrates what I'm talking about. On the Tracker it's about 1 5/8" from the end of the shaft rather than up near the end like this one.)
I've got a 8mm bolt threaded into the shaft and have yanked and yanked on it and the damn shaft will not budge out any further. Vehicle is back on the ground and has moved back and forth down my driveway and over the curb several times. Any thoughts?
Cause I just did an oil pan, trans service, cooler lines, and front wheel bearings on one of these things as a side job. While I was doing the oil pan I had to pull the front diff. What the hell retains the passenger side CV in the diff?
