broncoman6524
ok so on my moms truck we did a 6" lift a while back the Z-link bar. (i think) drop bracket has the 2 bolts on the frame and one on the center crossmember. the 1st bolt on the frame broke off, even with the nut. the frame in this area is boxed (right below steering box) and it has a sort or L shaped thingy that has a metal plate with the 2nuts for the above mentioned bolts as well as a L bend adn a cutout inthe frame to remove this. because the bolt broke off into the nut it wont come out. because inside the framerails there is a brace that we cant get to budge.
any suggestions? i know this is a long shot but me and dad have been working on this bitch for 4hours adn cant get the damn thing to come out
. we have unbolted the steering box, tried to get hte sawzall in the access hole to cut it. nothing has worked so far
