badmix
'84 Blazer.
1) I rarely drive at nite and dont remember if the a/c, vent, heater control area is suppose to light up. I pulled the instrument panel to fix the light behind fuel gauge and been testing the lights and those dont light up and not sure if they are suppose to. IF they are, than mine arent. POST #6 covers it, I got it!!!.
2) My parking brake cable running under the truck goes thru this metal bracket ( just below the drivers door) the problem is the bracket hole is pretty big and the cable is pulled to one side of the bracket to the point that its wearing thru the cable and the cable passes really close to the frame almost at an angle. Is this cable suppose to go straight back, parallel with the frame and not off at an angle and is there suppose to be something in this bracket like a grommet? I just went and checked it, its only really tight when the P brake is set, its loose when its released. anyway to keep it from rubbing thru? Can you guys take a look at yours and let me know. I can get a pic if need be.
Thanks.
Thanks.
