MrSchaeferPants
Ok the other day my driver and tailgate windows didn't roll up. Passenger is just fine. Fiddled with the tailgate and got that up, good to go for now.
Driver's window switch is all boogered up. Well the wire plug that pushes into the switch. Apparently the PO tried to fix it, sorta did, but stuck the broken terminal end, into another terminal end and crimped them. Anyhoo trying to touch wires to get it to go up. Apparently I don't know how a simple switch works
My blue and tan goto the motor. Pink is the hot, Black is ground. I'm touching touching touching, nothing's happening. I see ity bity sparks when I touch my brown (should be window up) to pink, but no go. I took all the wires out of the plug to try and get the passenger window to roll up, just so I know what wires to touch, and of course, w/o it being in the switch it didn't work.
What do I do just to get this up before it rains. Or at least what to touch to at least see if the motor is bad.
