2011 Forester X, 2.5l, fb25 non turbo, awd
This car is setting a P0171, lean code.
Today I smoke checked the intake, found a leak at the pcv. A pretty good leak, bingo got it.
Take it for a test drive runs better. Stalled coming to a stop 2x. The more it was driven the better it ran. Pull into shop shut it off. Try yo restart, cranks but light off. It wants to but just quite won't. Wait 5 minutes and it starts.
Sets code P0171 after restarting. Scan tool shows front o2 1.0v at idle,virtually no change in voltage. Maf shows 23-25 lb/h. inj pulse width 3.3-3.5 ms at idle, 2.5 ms at @ 2k. It is runing rich. I can smell it running rich.
In the last few months a lit of work has been done.
Cooling system leaks repaired,
New rad, 1 fan, hoses,o rings on cross over. Computer showing 203° F on scan tool.
Intake plenum new seals, throttle body cleaned and new seal, egr inlet tube new seals.
Egr valve new,( genuine Subaru)
Rebuilt injectors, fuel pump replaced. Pwm system.
Have inspected for upstream exhaust leaks nada. Re smoked the intake nada.
Vacuum guage shows a nice 17.7 in needle vibrates slighty at idle. Rev to 2k 21in ans steady needle.
I know i am leaving out other stuff i checked.
I am missing something here,
Need one of you to go did ya check .....
