Suburban bumper sale!
81jimmyslt
So Lake Tahoe (Rubicon), CA
We need to liquidate these three bumpers this month!
Best offer takes em.
Each set retails for $1200 give or take. Shipping is not included unless we personally make a deal, which wont be too hard pending on your offer of course.
Here is some pics of bumpers similar. The only difference bumpers will only fit 73-91 subs with tailgate, no barn doors.
If I can recoup half my money I will be happy.
1 - Rear HD bumper with swing out carrier, 1 jerry can mount, hi-lift mount, Tire mount is driver side. $1189.96 retail SOLD!!!!
2 - Rear Tube Winch bumper with swing down carrier, hi lift mount, two jerry can mounts, already painted Black. $1339.95 retail
3 - Rear HD with custom sides, has 1 3/4" tubing sides, Drop down carrier, Hi-lift, 2 jerry can mounts. $1239.95 retail
http://www.blazenoffroad.com/store/Bumpers-and-Tire-Carriers/
MAKE OFFER!
Thanks,
Jesse Kruger and BOR Crew
530-542-4034
[email protected]
id be very interested as my stock bumper met a boulder in a bad way...... but im afraid i could only afford to offer a borderline insultingly low price on em :(
Im assuming you dont have these installed on any trucks currently and couldnt take pics of them open?
It would seem that the bumpers pictured first and third would limit access to the cargo area, but number 2, with the swing away driver side tire mount would interest me the most. will the spare tire rack, and swing arm hinges handle the weight of an 8 lug H1 beadlock rim and 38-40in tire?
The swing out is the easiest to get in an out of the cargo area.
With four mounting points it will be plenty strong, but will likely need the side frame mounts we are working on as a seperate piece to limit flex when the tire is open. It would not be an issue if everyone had there fenders cut high but the extra side support is reccomended with larger than 35" tires.
Here are a couple of pics that I have of this bumper (I think). The tire carrier is included but not pictured.
Tim
so on the remaining two, how does that drop down carrier work? do you have to undo the two outside/higher bolts and then lever it down using the inner/lower bolts as the hinge point? im imagining those outside/higher bolts could be swapped out for some sort of quick release pin right? to make getting in and out of the rear of the truck less of a PITA. My main thing is i like to roll the window down and up alot, so the tire placement there makes it look like getting to the handle will be a pain.
Exactly. The upper two bolts can be replaced with quick release pins for quicker tire changes and tailgate opening. Would not be as easy to get to the rear window switch, don't you have a switch in the cab?
Jesse
