Suburban Rock Sliders?
mud390
Little Rock, Arkansas
I'm trying to find some rock sliders for my 83 burb. I'm not having much luck. I'd rather they bolt/weld to the frame to try to save the body as much as possible, but I haven't totally written off body mounted sliders. Any ideas? Thanks!
Kris
Check Blazenoffroad.com (81jimmyslt) and DPI they both have cheap sliders that bolt/weld on and I "think" I saw where both make them for Burbs for just a little more $$$.
I have seen one set of bolt on body mounted sliders locally in a truck sitting in a yard rotting away , loved how they did it too .
They cut the rockers out to the door sills , and instead of welding them to the body , the used thick walled tube with holes drilled and tapped , and drilled holes in each of the four door sills and actually bolted the sliders to the body . Then to copmlete the look they caulked the edge seam and painted it .
from a few feet away looks welded on :thumb:
A friend built my old ones.
They were attached to the cab on the block that goes from the rochers to the mounts.
