vandelay industries
Background:
1) Trans is new, reman ATI "streetrodder" TH-350. Has been working great the past year and no leaks that i know of (until now).
2) i park in the same spot all the time---home, work, friend's houses etc.
3) Tuesday morning i see A LOT of fluid under the truck. Not just a few drops (and even that isn't good because transes aren't supposed to leak....) but quite a bit of fluid. NOTE: truck was parked for only about 8 hours or so monday night.
4) So, the leak was SUDDEN, apparently starting monday night, and SEVERE (A LOT OF FLUID, LIKE MAYBE 1/4 TO 1/2 PINTS)
4) The only things i see is where the speedo cable screws into the trans. Also, there is a pan bolt that has some fluid on it and i suspect it needs to be retorqued, but there's no trail of fluid running down/across the trans. The trans case looks otherwise very dry and very clean .
Is the speedo output a potential leak point on a TH-350?
What other suggestions do you have?
