The Wedge - Buena Vista, CO
For land use and political reasons, I was at one point a member of the board of one of Colorado’s largest 4x clubs during the early 2000s.
While we did good work keeping trails open and working grants to help with other trails, I had joined with a good friend of mine who was already a member.
Formed into over a dozen "patrols", each patrol could invite whom ever from the main club to be in their patrol.
We used it more as a filter to recruit the crazier dumb bastards willing to thrash their junk to go wheel with us.
On Halloween of 2005, a group of us totaling 7-8 rigs went down to Buena Vista to run the "Carnage" trail.
Its nasty enough to have a sign in front of it warning you "Big tires and Lockers Required" sort of a thing.
We dropped in about 10 am, hoping to let the light glazing of snow melt off.
There’s several decent spots on that trail, one of which about 1/3 the way, is referred to as "the Wedge".
Two good-sized rocks with a V notch for passage (see above)
Somehow that day I managed to get shuffled into the middle of the group, ahead of a CJ-7.
Driver of said CJ we shall call "J".
J was known to be of a rather significant breed of tightwad not able to perform his own vehicle preparation work beyond an oil change.
His right foot never understood that though, and was often said to be playing the drum solo from Moby Dick
I made it over in decent fashion. J romped and stomped his way to the Wedge, bouncing off of it and back several times.
The CJ suffered some minor mechanical issues. By minor I mean he never tied the battery down with anything more than a bungee cord.
The battery came loose and stomped the crap out of the distributor cap, lights out.
No way around it, the CJ would have to go up the trail to get back out.
We winched it over using the battery in the CJ, but it was crapping out fast due to the motor not running.
At this point it was already late afternoon, and we were running out of daylight.
Someone produced a chain about 20 foot long, so I hooked one end to the K5, the other to the front of the CJ.
Off we went at a snails pace.
I tried to be nice. But at about 6 PM, and listening to J bitch about how I was dragging him over rocks to fast, I started to lose my patience.
Still only half ways up the trail.
The bolts had fallen out of the steering box on the CJ. No steering.
Another chain was used to triangulate to the high steer arms on the CJ, the only point on that POS on the front to chain to make it steer.
I started back up the trail for quite a ways.
At damn near dark 30, POS CJ gets pretty well double whammied.
I bumped it a few times, no dice. At this point, I decided the CJ was going to move.
I backed up to gain a little slack.
Now I didn’t know this at the time, but wheels will make sparks on rocks, too.
I dropped it into 2nd gear and dumped the clutch at about 3500 RPM.
Things flew, like sparks, rocks, logs, Jeeps parts. You know, stuff. That managed to bounce us about 100 yards up the trail to the exit.
The exit to the left, a nice steep rock face, or right, a sheer rock wall.
Winch out for all of us. Slow pulling getting a good running vehicle out, it took us several hours to move the runners over the ledge.
It was cold that night, not sure how low, but I was wearing Carhardtts.
Finally dipped an empty pop can into the fuel cell and pulled out some gas to start a fire with all the wet wood.
After turning around, chained the rear axle of the K5 to a tree, and ran all but three wraps out on the winch
Took 4 winch cables to drag Dead Jeep over the ledge.
By this point, the high steer arms, tie rod, drag link, frame, window frame, and front axle tube was bent on the CJ.
J was crying up a storm how we damaged his Jeep.
Several offers were made to burn the Jeep at that point, but we were at the top finally.
We made it down the return to the lot where we had thankfully parked a trailer with a truck and camper. Lit the little furnace and crawled into the sack at 3:45 am.
