Superlift front spring?
scooter122983
Fond du Lac, WI
Is it possible to take off the bottom spring leafs on my front springs to achieve a lower spring rate, and then put zero-rates in to fill the void, or would i be able to do it without the zero-rates? Or would I be better off buying softer springs.
I removed the lower two leafs off my 6-inch Superlifts, and they ride much smoother now. I did have to pick up some shorter center bolts since I didn't use zero-rates though, and a new set of u-bolts since the old ones' threads were damaged from being pressed against the springs/axles.
i removed leaves out of packs numerous times for people. I also grease them with a heavy duty marine application style grease to help reduce friciton (and make stuff stick to them). It does work and there wasn't really a difference in lift odd enough.
i have superlift softride 6" front leafs... they are so soft that the leafs actually sit at 5" on the truck... then my ord zero rates put me back at 6" :crazy:
Did that to the 12" fronts I once had on my 89. Took the bottom two out, lowered it some and actually made the suspesion move!!!
