So I picked up the jimmy about a year ago after selling my Camaro, and needing a new project to start. I've been slowing wheeling and building as i go, and hi-jacking other peoples threads with my build pictures so i figured i'd start my own build thread and back date a little bit to bring it up to date. I'm kind of hoping that this motivates me to take more pictures of my work and progress.
So i'll start where it all started this is the Camaro that i sold
I found my jimmy on Craigslist, the guy said it had carb problems, and it kept had a broken rear u joint blew 3 in the last 100 miles he drove it then it sat for 3 years because he couldn't figure it out.
and the wife
Did i mention it was ****ing purple.
I pulled the top off to see what kind of rust was around the window frame.
turned out the problem with the piece of **** 2 barrel carb was that it had been sitting for so long, exactly what i expected. Little carb choke cleaner and it ran, like a 350 with a 2 barrel... the U joint issue as far as i can tell when it broke the first time from being worn out, who ever changed it reclocked the driveshaft wrong and cause it too eat up the rest of them. fixed it didn't break one for over a year.
time for better power and smoother running. In the form of a Edelbrock performer intake and after alot of research and previous experiences with holleys and edlebrocks while wheeling i decided on a brand new worked quadrajet.
I also swapped out the mechanical clutchless fan for acouple of electric pusher fans with an adjustable thermastat.
the purple finally had to go so what better way then the free labor of my wife.
and the wife
GRRRR!!!! i just deleted a giant post that i was almost done with i'll redo it after lunch
this guy. (I do Now)
