Suspension Shocks
90GMCJim
Bay Area
Hello everyone.
When i did my axle swap i replaced the bushings in my original leaf springs. The time has come to replace the springs.
I am going with ORD custom springs. 2" lift. I want the most comfortable ride i can have for street use.
I currently have ORD bushings with bilstein 5100 shocks.
When i replace with the ORD custom springs are king or fox 2.5 shocks overkill? either or will run around $500 plus.
Will fox 2.0's be better for my setup as im not going offroad.
I am in california and i do drive to work which is a 30-45 min commute. City driving sucks as the road are horrible.
Main concern is having the family in and everyone is jumping around on dips or rough roads.
Thank you
Hello everyone.
Thank you
Just go with bilstein
Off the shelf Bilstein will likely be firmer than the Fox 2.0, but you should check with ORD. They offer a different valving from Bilstein that is supposedly better matched to their springs. They can give you good advice based on your intended use.
