I'm probably just going to get a twinstick kit anyway.
If you want to twin stick the 205 then you MUST tear some of the t-case apart to remove the shift rail and either modify the shift rail or replace it with a new one from ORD that will allow for twin stick capabilities.![]()
Any issues fishing those two pieces out of the tcase after you punch them?
BTW, I was coming home from thestore last night... as I made the two right hand turns into my neighborhood, the rear (it felt like) wheels started chirping and binding up. Front hubs are unlocked. Think I might need a new rearend?? This is getting interesting!![]()
sounds like it might have a locker in it, they are kind of funny if your not used to them took me a while in my truck to get used to it. worth checking out though to make sure. also just in case if your TH350 to 205 adaptor is bad advanced adaptors makes a replacement mine was cracked ordered and intalled works perfect (AA part number #50-5302) im nearby in Orange County, need a hand feel free to ask.
